I, periodically, get a popup on my iMac screen reminding me that XXX is only 32 bit and won’t work in the next macOS. Unfortunately, most of my bad apps don’t have update / upgrade paths and many I don’t use anymore.
So my question: Can I just go into my Application Folder and delete those Apps that I don’t care about?
Or am I going to have to look for Uninstallers to remove all their residual crud?
Thanks
Jerry
