One more observation: Setting up our new iPhone 18 Pros has been massively frustrating and problematic; the worst experience I’ve had in 40+ years with Apple devices. It took me 3 tries to do my phone and when I finally got the process started, it took more than 3 hours (about 300gb) - apparently it sent all that data up to iCloud and down to the new phone, despite those two being plugged together with an USB cable. So far wife is on her second try, and only some settings have been transferred..
Updated my iPhone 18 Pro and Watch Ultra 3 this morning. Took more than 30 minutes each to download and install. Wish I’d waited for it happen overnight. Quite the load for a “dot” release.
Their marketing dept has to have something to do so they redesign icons and “themes”. Over the decades I think that Mac apps and icons have deteriorated as they have been aligned with iPhone ones. Keynote is my biggest bugbear.
BTW what are those silvery disks in the early Music icons? ![]()
The USB connection may have been the problem. Only the iPhone 15-18 Pro, Pro Max, and the iPhone Duo can transfer at USB3 rates. Others are limited to 480mb/sec (USB 2) speeds. Most USB-C cables 9e.g Apple charging cables) also are limited to USB 2 speeds. You can use a tool like WhatCable to check your cable.
I believe you can leave it off. It uses ChatGPT, which needs to be set up. The new version of iOS does take up a lot of space, however, and the indexing process can take a couple of days.
Did the same on iOS.
Since I complained about it earlier, I should acknowledge that macOS 27.2 has restored a more informative graphic that appears when you adjust the system audio volume. One of the list of “small improvements.”
Heh – I came to this thread to mention this – along with the Display Brightness are much easier for these 62 year old eyes to see.
To be clear, Apple Intelligence does not require ChatGPT. It’s merely an option if you prefer to use it. Configure it in Settings > Siri > ChatGPT.
@glennf just wrote a little bit more about reverting to Siri Classic.
Frankly, I see absolutely no reason to do this. Siri was lousy before, and Siri AI is far more capable, if a little slow at times.
Depends on what you do with it.
I never use Siri for more than executing simple commands, which its script-based engine has no problem with. For example:
- Start a timer for 30 minutes.
- What’s the weather forecast for today?
- Navigate from my location to home (or some other location known to the Maps app)
- Increase the display brightness by 20%.
- Read the text message that just arrived.
- Call (someone in my contacts list) on speaker.
For simple things like this, I suspect AI might create a worse experience, by overcomplicating what should be a trivially simple request.
It’s still in Beta, however, the Siri AI setting, that is.
Please Note (!) that in 27.2, if asked, Siri AI will freely waltz into 1Password to retrieve 1PW information! What a shock this was for me - I tried it thinking that couldn’t possibly happen. I have just used Settings > Siri > Excluded Apps > 1Password to restrict access.
Late to the party but I’d agree that on my SE 2 the 'security is more and ludicrously invasive.
If I have taken a 10 minute phone call, then added urgent texts, and put the phone down for 5 minutes- I should not need to re-enter two security passes that just wastes my time 5-6 times a day!
I’m on the same nw at the same location 95% of the week- this has been happening since before Tahoe ever appeared.
Frankly I’m sick of it!
Just updating to this version now; d/L was cited at 663MB and yet it complained on first step that it required 11.x GB of space. Its a 64GB piece which was a vast improvement over a lagardly iPh6 beforehand.
Sorry for a bitch session reply, any suggestions for a pensioner?
Thanks dave
Apparently, there is an update to macOS 27.2 for the new models that were just announced.
I just got around to updating my Apple TV to 27.2. I am disappointed that the ATV Music app has become as messy as the TV app. The simple menu items across the top of the screen are gone and I have to wade through new menus to find items.
I give up on worrying about app icon changes, (caution: rant statements ahead ;-) ) Apple must have a very large and bored creative department. When they could be improving the readability of everyday things (the charging icon on a lock screen widget for example-can’t read it without glasses no matter what Accessibility setting I use), they’re putting icons in Menus where they don’t belong, and changing app icons.
But if it keeps the company growing that will help me eventually. ![]()
