Nisus Writer: Schrödinger’s Word Processor
I wonder if this is something a Shortcut could do. And soon it’ll be somewhat easy to test it with OS 27 able to create a shortcut from a prompt.
Write Mellel! They are really respnsive.
@jeff1 , I’m a bit late catching up on this Topic, but found your comments something I might be able to help with, but ended up with a mixed bag.
Not sure what you’ve moved on to in 23 days since the post, and I’ve never used Nisus but appreciate the user passion displayed in this topic.
I’ve used Pages casually over many years, having no need to produce documents for work or letter writing etc. but am roughly familiar with its features. Any time I get a new software product one my first steps is to investigate its Settings/Preferences. Wanted to share the following:
  • Start in native format: Not sure this can be avoided (in any office/writing software) or what format you want. I tried Pages’ Template feature by starting a new doc, typing a few words and Exporting to Plain Text (among 8 other options), then opened it in Pages, saved as a Template, hoping that would do it but it opened in TextEdit. So depending on needs, Export may or not fit for you, but a txt format Template doesn’t seem to be right. Maybe there is an Automation or Script or Shortcut to suit need, or you could try using TextEdit in rtf mode if you need some amount of typographic fun.
  • Spell checking/correction: I have only one Auto-Correction option ticked (am also not a fan of much auto-anything), for smart quotes, yet correction squiggles appear under individual words in Pages:
    That might be a function of settings in System Settings > Keyboard > Text Input > Input Sources Edit…
    or maybe some other setting I can’t think of now. So there might be a way in Pages or Settings to address those disappointments.
  • Accepting your changes: I’m not sure what method you’re using to teach Pages what changes to accept.
    I’ve had good luck with context menu “Learn Spelling” over the years. I just made this example above, told it to learn, the squiggles disappeared, and then I context clicked to “unlearn” and the squiggles reappeared.
Hope that helps you or someone else.
Thanks for the suggestions. Fortunately, jeab wrote seven days ago “Today, on the day before the expiry date, the nisus.com registry was updated, and is now valid until 2031-07-07.” That solves the immediate problem for me.
When I have the time and energy I will take another look at Pages. I like its simplicity, but it lacks some features, and I remember being burned by some of Apple’s past failure to support the original MacWrite and other early word processors.
@jeab I just found that my Nisus license field is empty, and that visiting nisus.com fails.
End of an era?
Anyone have any luck?
I was able to open the License information and I can use Nisus Writer to open, write and save, but could not get into the Update field. So it still seems usable to me.
It loads for me, my license field is full, and I can visit Nisus.com, though it is a slow as treacle…
Gateway Times out here, sadly.
I have found that Nisus no longer puts a watermark on printed documents - it opened with a blurb saying it needs my approval for it to access something or other (this was a bit ago and I’m getting old) and I denied the request and so it opened with no difficulty. The loading of my prefs etc took awhile to load so my answer was to just keep the app open all the time. Everything is working very well. Hope this is of help to some one.
I have Nisus Writer Pro v. 3.4.1. I just went to print an old Nisus Writer document, and I saw the “demo” watermark in print preview. So I went to “Licenses…” and found both fields empty. I entered the license code and customer name for NWP 3, and an error message popped up, saying, “The entered license key has been revoked.” WTF?? The Nisus website is unresponsive. What’s the next step, switch to some other word processor?
This is so sad. I kept hoping some company would purchase the assets. Such a great word processor for scholarly writing.
Ah, I got the empty license fields today and upon entering them it too hit a gateway timeout.
Dang, what now… I was hoping there’d be a future for it, the user base is devoted and longterm. A great case for open sourcing it.
I just went to a test account on my Mac, launched NWP for the first time there, and tried to enter my license. While I was doing this, Little Snitch alerted me that NWP wanted to connect to nisus.com. I denied this, and the license worked fine. I have not tried to do this while allowing the connection.
FWIW, my copy of Nisus Writer Express seems to still be operating normally and shows a license.
I have transitioned away from creating new documents in Nisus though, so I’m using it pretty lightly these days.
Well, I waited too long. Because I am invested (thousands of NW docs and dozens of key macros) I am committing to an intel MacBook going forward. But I need an install package. The main site is down, and Macupdate seems down as well. Where can I get an installer for my licensed use?
Simply copy the app from your old computer. No special installer required.
Good news. Thank you. I am in the process of reviving an intel MacBook Pro, because of course. It reminds me of possibly my happiest most cherished time with writing. A Pismo with what is now called Nisus classic feeding FrameMaker using a new thing called WiFi.
Seems like the Internet Archive Wayback Machine has archived it:
Fortunately, opening Nisus rtf files in other word processors is most often painless. But it is not completely painless. One issue is that applications like LibreOffice may not always recognise the fonts, and look in vain for “TimesNewRomanPSMT” and similar. I have found that this is a fairly easy problem to solve, at least in my case. Simply change this (and similar):
{\f0\froman\fcharset77 TimesNewRomanPSMT{*\falt Times New Roman};}
into something like this:
{\f0\froman\fcharset77 Times New Roman;}
But I found a bigger problem: I have a lot of zrtf files, and many of these files have pictures in them, typically jpeg or png (but also embedded pdf, see below).
The zrtf files are basically the same as .rtf.gz, but as I notice now, pictures are encoded differently in the two file formats. So when I gunzip the zrtf file and open the resulting rtf file in another word processor, the document does not display my jpeg or png pictures. If I use Nisus to save as rtf first, it seems to work fine, but I cannot do that with three thousand files all across my disk.
File Juicer is actually able to extract the pictures from these files, whether they are rtf, zrtf or gunzipped zrtf, so the pictures have not been lost. They just won’t show in LibreOffice or Word.
And then there are the embedded pdf’s. This is a bonus problem that I was actually aware of in advance: Embedded pdf files with vector graphics are encoded in such a way that when the Nisus rtf files are opened in other word processors, only a low-resolution bitmap fallback is displayed. I was once told in an e-mail exchange with Nisus that this implementation was chosen due to a limitation in the rtf format. I was also informed that there is a hack to make Word accept the embedded pdf files (the hack is to embed the pdf as Windows Meta Data instead; Word does this, if I remember correctly). I have successfully tried to do this manually, but for me it would be easier to use File Juicer and reconstruct such documents. LibreOffice does not accept embedded pdf anyways, but if done in the Word way, at least LibreOffice converts the pdf graphics to something with a higher resolution than the mere fallback.
Whoever is able to make an application that can convert from .zrtf to regular .rtf with embedded pictures, perhaps even with embedded pdf, will be my next great hero.
Is nisus.com working for anyone now?
