MS is at it again: perm licence MSO 2021 gets deactivated
MS is at it again. If you have a permanent licence of MS Office Home & Business 2021, specifically version 16.114 and higher, you may see suddenly a message that your MSO is not activated (anymore). MSO goes into Read-only mode, you can’t edit any of your documents. Imagine if you’re working to a deadline :angry:. Refreshing the license (Under About Word > More Info) produces an error and no activation. All of this happens when you have a valid and paid-for licence in your MS account. Plenty of advertising during this chaos tries to drag you on a MS 365 subscription which you absolutely don’t need (or want).
I surfed up a solution, see here and I can confirm that it works. To summarise (YESS, with an ‘s’ in Britain :grinning_face:)
  • use MS’s Licence Removal Tool, here, then restart the Mac
  • delete all MSO apps, EDGE and TEAMS can stay
  • reinstall v 16.113, which can be found here
  • switch off automatic MSO updates
Good luck
I ran into the same problem and found a similar answer here. I decided to buy the 2024 version for $10 from this site. Softmall is a UK Microsoft partner. Easy install instructions are included. My apps say “Office LTSC Standard for Mac 2024.” This offer has been available for several months, so it appears to be permanent.
Can you please clarify/edit… title says 2011 but your post says 2021.
If only there was a way to turn off the auto launch of Microsoft’s AutoUpdate app!! Irritating that it will autolaunch itself multiple times a day.
In General > Login Items & Extensions > Allow in the Background (under Sequoia 15.7.9), I turn off AutoUpdate’s permission. IIRC, Microsoft almost instantly presents an error, I Force-Quit AutoUpdate and some Microsoft error reporting program, and restart. (I believe I do this with no internet connection; I don’t know if that’s significant.) After restart, I go about my business with no whining from Microsoft about installing updates.
I’ve been meaning to post about that! I was forced to reinstall the apps back in August and now that autoupdate gets stuck every time I open Excel or Word! There’s no way to stop it?!
Super annoying when my machine loses connection to the keyboard and I can’t force quit it.
I don’t know about turning off auto-launch, but presuming it relies on an internet connection, you might be able to use Little Snitch to block its connection. Maybe that helps, maybe not, just wanted to offer the idea.
I have turned off Microsoft AutoUpdate in General > Login Items & Extensions > Allow in the Background and I have blocked all connections to Microsoft using Little Snitch.
I have never been notified that I need to update my Microsoft apps.
Thanks to an earlier, very lengthy Tidbits discussion about Office 2021 going bye-bye, I’ve bought the $10 Microsoft Office for two computers. It seems to be working fine.
Thank you for this information. I have 2 Macs and paid near full price to install Office 2024 on one but thanks to this link I now have Office 2024 on the other for just $10. The installation process using Softmall seemed to run more smoothly than using Microsoft!
From the release notes for Microsoft Office 16.114.4:
  • A previous update inadvertently disabled Office 2021 for existing users. This update resolves the issue and fully restores functionality for affected customers.
Note: Office 16.115 just came out today.
