Inscrutable, indeed! Are you sure you have all the updates to Office 2011 installed? Grasping at straws…
Adam,
Yes, I am. I’ve compared them with those I am using on my iMac Pro, running Mojave, which are definitely up-to-date. I’ve even tried copying over the application support files (the Microsoft folders in /Library/Application support and /Library/Preferences). I’ve fiddled with the VM settings. Nothing makes any difference. I’m stumped.
Jeremy
The best course of action would probably be to treat this as a Parallels problem and contact their support.
Good idea! I’ll give it a go.
Jeremy
Is it still true that Parallels can’t create a macOS VM from a clone? I just want to make sure I didn’t miss it. Looks to me like you first need to create a vanilla VM with an OS X installer and then use MA to get back your data from the clone. Is that still the proper way to do this?
@glennf and @amilholl-TidBits
When you tested out Address Labels, does it have the ability to print barcodes like BeLight’s Labels & Addresses could?
