I think that I might have the perfect thing for you! I just became aware of it. And the price is right!
Ivinci Express (free)
http://phyar.cn
http://phyar.cn
Everyone seems to be in a bad mood these days. It’s off-putting, but I just keep my head down and do my best to be helpful to folks, even when no one seems very appreciative. I hope that one of the products that I’ve pointed out ends up being of use to you.
Randy B. Singer
Co-author of The Macintosh Bible (4th, 5th, and 6th editions)
Essential But Hard To Find Macintosh Software and Advice
http://www.macattorney.com/welcome.html
In the past I have used Illustrator to annotate maps, but this is clearly using an expensive sledgehammer to perform a simple task… Can any of your suggestions draw versatile vector lines / arrows (with control points etc) and rendered shadow as in the screenshot. For simple arrows I can annotate with Preview, but arrow styles are very limited, control not so good and no shadow…
Grateful for any suggestions
I suggest taking a look at Affinity Designer for this.
It probably qualifies as a “sledgehammer” for this particular task, but at least it’s not an expensive one. A permanent license costs US$69 at this writing, and a free 30 day trial is available.
You can set the ‘slide’ size to be a paper size if you wish under Page Setup in Powerpoint. There’s all the usual listed there.
I also turn on View Rulers and View Guides, the combination of those and Page Setup make PP a reliable simple graphics tool.
