iPad mini Gets Larger OLED Display, A20 Pro, and Landscape-Edge Camera
Originally published at: iPad mini Gets Larger OLED Display, A20 Pro, and Landscape-Edge Camera - TidBITS
Apple has unveiled what may be its most substantial update to the iPad mini ever, bringing a larger OLED display, the new A20 Pro chip, a 12-megapixel Center Stage camera on the landscape edge, and water resistance to its most portable iPad. The new iPad mini is only 5.4 mm thick and weighs either 255 or 263 g depending on the model, making it 14% thinner and 13% lighter than its predecessor.
This new iPad mini’s enhanced feature set doesn’t come cheap. The Wi-Fi model starts at $699, and the Wi-Fi + Cellular model at $849. Apple raised the iPad mini price in June (see “Apple Raises Prices for Many Products,” 26 June 2026) from $499 to $599 for the A17 Pro model, and this new version adds another $100 on top of that. The iPad mini now costs 40% more than it did four months ago.
The new iPad mini comes only in midnight and starlight (no more blue, purple, or space gray colors) with 128 GB, 256 GB, and 512 GB storage options. The iPad mini works with both Apple Pencil Pro ($129) and Apple Pencil (USB-C) ($79).
Pre-orders are open now, with availability starting 6 November 2026.
Larger, Brighter, Blacker OLED Display
The iPad mini’s most visible upgrade is the new 8.5-inch Super Retina XDR display, which expands from the previous 8.3 inches while maintaining the iPad mini’s physical footprint, thanks to thinner bezels.
Apple makes much of the new OLED display, promoting the pixel-level lighting control for deeper blacks that iPhone users have experienced since the iPhone X. Along with the iPhone, Apple currently uses OLED displays in all Apple Watch models and recent iPad Pro models.
Peak brightness jumps to 1200 nits, more than double the previous generation, and the display can dim to just 1 nit for use in dark environments—useful for reading in bed. The increased brightness and 2,000,000:1 contrast ratio will be welcome for those who work outdoors or in challenging lighting. To reduce glare, Apple also offers a $100 nano-texture glass option on the 256 GB and 512 GB models, as on the iPad Pro.
New Cameras and Audio System
Several other changes tweak the iPad mini’s industrial design. Most notably, the 12-megapixel Center Stage front camera has moved to the landscape edge, finally making video calls feel natural when the iPad is in its typical landscape orientation. The 12-megapixel rear camera gains an Adaptive True Tone flash that Apple says improves both low-light photography and document scanning.
Even more unusual is what Apple calls an Acoustic Display—a redesigned audio system that hides woofers and tweeters beneath the iPad mini’s glass and aluminum enclosure. Apple claims this delivers punchier bass and clearer highs, but more interestingly, the sealed design makes the iPad mini the first iPad with an IP67 rating for water and dust resistance. At least when it’s new, that means it should be able to survive submersion in up to 1 m of water for 30 minutes. I still don’t recommend dropping it in the pool, but it won’t mind being caught in a drizzle.
More Performance from the A20 Pro, N1, and C2 Chips
Apple has outfitted the new iPad mini with the A20 Pro chip used in the iPhone 18 Pro models. Compared to the A17 Pro iPad mini, it delivers up to 4.5x faster AI performance, 2.7x faster graphics, and 60% faster multithreaded CPU performance.
Apple included its custom networking chips: the N1 wireless chip for Wi-Fi 7, Bluetooth 6, and Thread, plus—in cellular models—the C2 modem for up to 50% faster cellular speeds with improved power efficiency. The iPad mini uses eSIM exclusively, with no physical SIM card slot.
Performance wasn’t a common complaint with previous versions of the iPad mini, so while the faster performance is welcome, it’s unlikely to be the primary reason most people buy one.
Purchasing Decisions
If you have a sixth-generation iPad mini from 2021 or an earlier model, the A20 Pro iPad mini is a massive upgrade in every way—display quality, performance, cameras, and durability. The improvements are less dramatic for those with an A17 Pro iPad mini from 2024, but they’re still noticeable.
However, the real question surrounding upgrades is how you use your existing iPad mini and whether the improvements would make a noticeable difference to you. It’s not like the screen was bad before, and most people probably weren’t running performance-intensive apps on an iPad mini to begin with. Water resistance is certainly welcome, but again, relatively few people put their iPad minis in situations where they might get wet.
I suspect that most iPad mini users are pretty happy with their existing devices and will be tempted to upgrade mostly to address poor battery life, a cracked screen, or some other physical problem. That’s not to say you shouldn’t upgrade if you want to, just that the iPad mini wasn’t doing a bad job before. Anyone considering their first iPad mini now will appreciate the improvements.
The overall cost is more of an issue. At $699, the iPad mini costs $250 more than the $449 base-level iPad with an A16 chip, and only $50 less than the $749 11-inch iPad Air with an M4 chip. More so than ever before, you’re paying a premium for the iPad mini’s compact form factor. But if a small iPad is precisely what you want, this iPad mini is the best one Apple has made.
Perspective is a funny thing. I used to think iPad minis were too expensive for what you got. But I ordered a Duo specifically to function as a pocketable iPad mini. With that costing $2K, this mini seems cheap! :laughing:
That said, what do you do with a tiny iPad? Read books? Watch movies? Do you really need all these extra high-priced features? For people with only one iPad who want a small one and want to do more stuff with it, I could see this making sense, but for most a bigger iPad is better or a cheaper mini to use a secondary device would be preferable. I think Apple should work on a $299 iPad mini.
I have a first-gen mini that’s so old it takes minutes for apps to launch. It still sort of works, though. I can read books on it. Barely. :wink:
I’ll get one for sure. My iPad mini 7 gets a lot of use every day, and it looks like it is still worth $340 as a trade, so it is worth the extra cost to get a new battery and screen, plus possible performance gains. I’ve always found the larger iPads too heavy for comfort for the things I use it for.
I was interested in upgrading my iPad Mini 5 – but the price of this makes it easier to keep using the old Mini. I mostly use it for email, some light web browsing, and when I am traveling but don’t want to bring the MacBook Pro. It also gets used to stream Apple TV+. I don’t think any of those will benefit enough to matter from the upgraded hardware.
Pre-ordering starts at 10:10 AM PDT on 28 Oct 28 with availability 6 Nov.
A20 Pro chip:
5-core CPU, 7-core GPU
16-core Neural Engine (128 & 256 GB models, Dual 16-core on 512 GB model)
Nano-texture glass available in models with 256GB and 512GB storage
I’ll be ordering one, just have to decide 256 or 512 GB
Spotted the video on YouTube.
Nothing wrong with my one, the last version. I’ve the 256gb model, it goes with me everywhere, no storage issues.
I have a 256G iPad Mini 6. The version before the last version. I’m tempted by the better video and significant increase in performance of the Mini 8. But having 2nd thoughts since a 256 G(128 not being enough for me) Mini 8 costs twice what I paid for my 256G Mini 6. Am wondering if the video and CPU+GPU (and memory bandwith) upgraded hardware are worth it, to me, at least.
We have two iPads in the family that recently have seen their likely last updates. The specs on these new minis are decent, but I can’t justify spending $699 for them. TBH, I’m not sure $549 for a regular 256 GB iPad is worth it, either, never mind the cost of adding a keyboard or other accessories.
On 2nd thought, really shouldn’t think backwards about how much something cost in the past.
Rather: is the new model is worth it, to me, going into the future, considering the cost as the current sales price minus the current trade-in value of the old one.
When I get the Mini 8, my 7 will become the backup replacing 6. The 256 GB will be sufficient. I don’t need to buy a keyboard as I have the one that came with the iMac; it is currently paired to my  TV 4K.
As a financial markets person, I agree. The price is the price today and the benefits provided by a new iPad begin after the purchase is made.
I’m waiting for the M6 iPad Pro…but it’s being a long wait.
I have a perhaps odd approach on this. I’m more or less retired and find myself with too many gadgets to charge and maintain. As soon as possible with family considerations I want to retire iPhone 13 Mini and replace it a ‘seniors phone’ (calls and SMS only) and a Mini.
I’ve had and enjoyed Minis since at least the 4, used them in various ways including in flight planning and professional flying. The 8 (A20) looks pretty good but yeah expensive but hopefully it will be the last Apple gadget I purchase and last a long time.
Went through the purchase steps the other day and wanted to trade in an iPad Air that rarely gets used, and a Mini 6 but appears you can only do one item trade-in at purchase and it’s only a discounted purchase price if you use the time-payment option. Paying in full means you later get a credit toward future purchases. So I suppose I’ll hold off on the accessories til the trade in gets processed.
Also want to check, I think I’ve seen in past that you can save a purchase configuration for later. That might make the process faster this evening. Purchasing here in EU and wondering if all that AI stuff will be installed on it, since supposedly it’s not allowed to be used here.
Can only imagine the stress of the Apple IT Squads as they get ready for the ordering onslaught for this and other new stuff.
Well, just ordered. Had saved the configuration and at a few seconds past available time I clicked ‘buy’. Some confusion followed, an old saved configuration of a MBAir appeared in my cart and was not obvious how to remove it.
After 9 minutes I got a new order set up and by then delivery time had slipped a week already. Ah well.
Things may be different in the EU, but I had no problem receiving a credit for my old MacStudio after trading it in for a new one in the USA. I received the credit on the same credit card I used for the purchase, effectively reducing my balance.
Thanks @aforkosh , I hope it actually works that way, perhaps I read the fine print too fast, but I entered all the info and there was a small notice that the amount ‘due today’ was the full price and that I would be getting a box and ipad preparation instructions for the return. Might be different rules on such things here as you noted.
I still use an iPad Mini 5 regularly. I have the Cesium app and a fair amount of music on it, and for certain of my jobs or for travel I like to have it along. It fits easily in my bag, where a regular-sized iPad would not, with room for my headphones. I’ve used it much more than my larger iPads. One of those is (I think) a second-gen iPad Air, and that one is mostly used as a tiny TV in my workspace.
The new Mini looks tempting, although I’d want to be sure that I could disable Siri and all the AI stuff.
It all depends on the use case. My mini 5 is perfectly adequate for web browsing, webinars, and reading PDF educational materials. My mini 7 cellular/GPS is marginally adequate for private aviation, due to screen brightness (low) and reflectivity (high).
Sigh. I guess I’ll soon be getting a mini 8 with cellular (for the built-in GPS) and nano-texture screen. Sorry, wallet.
And a big “hell no” on AI features of any kind. Not trustworthy in the flight deck.
To help with that you could try trading in a lesser used Apple device, and if you’re a veteran take advantage of the veteran discount program (id .me account req’d).
I’m ironically seeing in recent days more references to the Mini being used by pilots. There was an interview with some Apple execs (Six Colors I think) where helicopter pilot use was mentioned, and over the years lots of built-in screens in aircraft have roughly the same size.
It resonates, as I impressed a tech-averse lead helicopter pilot many years ago with use of a cellular capable regular sized iPad to navigate us around a thunderstorm cell and between airspaces in a metro area. We had only an aging onboard weather radar, which didn’t give us the whole picture of the extent of the cell.
And years after that used a Mini with some software (forget the name now), later bought by Jeppesen, for weather reports and maps with present position, etc. Really helped when flying single pilot without a built-in GPS display.
There are a few pilots who fly “heavy” jets and have YouTube channels. I often hear them referring casually to their airline-issued cockpit iPads.
Regarding navigating around thunderstorm cells, flying through a massive thunderstorm seems to have been a major factor in the recent crash of a Learjet in Palm Beach, FL. Normally, planes are directed around them, so there has been speculation about what heppened. Could a cockpit iPad have led to a different outcome?
