On my 12 mini (with the latest iOS 14 updates) I frequently use the Control Center toggle to turn on DND when I go to bed. Most times I choose the option ‘Until tomorrow morning’. I’ve noticed with iOS 14 though that often the toggle will switch to on, but DND will not actually activate (no moon icon in the status bar). To fix it, I’ll have to turn the toggle off, exit Control Center, and then start again from scratch. Sometimes I’ll have to repeat that two or three times until I finally get DND to actually engage.
Has anybody else seen this? Any way to fix this behavior? The workaround of course would be to manually engage DND via Settings or to run it on a fixed schedule. The former I don’t want to do because I know I’ll end up forgetting to turn it off again in the morning, while the latter doesn’t work really well for me because my schedule changes from day to day depending on what’s going on at work.
If anybody has a trick to get around this bug (yes, I submitted it), I’d really appreciate hearing about it.
