Following those instructions I don’t see the option for Share a Link. All I get for any regular PDF sitting in my iCloud folder is Collaborate or Send Copy. ![]()
Edit: Update from 26 to 27 and the option to Send a Link does appear.
I don’t have terabytes of data to back up – maybe 500gb in total, perhaps a little more.
For many, many years, I’ve hard-partitioned my internal drives into four “pieces”:
My object for doing this goes back to the days of the Macintosh SE and SE30, that being to keep your boot OS “separated” from your files on another partition. If the boot partition crashed, chances are, your data would be left untouched.
It’s worked for me for a long time, and approaching age 80, I won’t be changing it.
Having said that, I use CCC for backups.
The backups are scattered around:
“Next to the Mac” backup – (first two partitions on a 2.5" bare SSD sitting in a USB3/SATA dock, the Music and Media are on a platter-based HDD). These are on the same desk as the Mini, but are DISCONNECTED from the Mac when not actually doing a backup (and unplugged from the wall, too).
“Basement” backup – platter-based 2.5" HDD which I keep in a water and fire-resistant lockbox in the basement.
“Car backup” – Samsung T7 “Shield” SSD I keep in the car. In my working days, I kept my “offsite backup” in my locker at work, but now the car will do (a location outside of my house). The “Main” partition on this drive is password protected – if the car is stolen, they get “the drive”, but my personal data will be encrypted. This is the ONLY partition on ANY drive I have that has encryption. I WANT my files to be “easy to get to”.
Separating these volumes makes incremental backups go quickly.
If I run my “boot” backup to my on-desk SSD, it normally takes about 35-60 seconds.
When I run my “Main” backup, it takes 0 seconds. That IS NOT a mis-type – CCC copies over 30-40 or so small files that quickly.
I’ve never used time machine, not once, not ever. No need for it.
Current releases of CCC use the macOS file-system events service (the same one that drives Time Machine), so it will only look in those directories that contain modified files and won’t even look elsewhere.
This greatly speeds up incremental backups, as long as you perform them frequently enough that the FS Events database is still current (about 1-2 weeks, I think). If you let more time go between backups, so that your backup is older than the oldest event, then it has to fall back to the older method of comparing everything to the target volume in order to know what changed. That can take much longer.
FWIW, on the faster of my two backup HDDs, a backup takes about 15-20 minutes if it has to inspect everything. About 3-5 minutes if the FS Events data is still current. On the slower HDD, about 2x that time. I manually trigger my backups (relying on Time Machine for automated backups) about once a week, but I sometimes forget and then they may take much longer to complete.
I don’t think a backup time of only 1 minute is unreasonable if your backups are being performed often enough that the FS Events data remains current, and your working application data (especially browser caches) is on a different volume.
One thing I like about the way files and folders work in Dropbox is you don’t need to keep the files on your device. You can specify a folder to be “in the cloud only” - which means you can get to it via the web, or enable downloading to your Mac if needed. But I use that feature for backing up large files I don’t really need anymore (I think), like old customer databases, so they don’t take up space on my Mac but are still there if I need them.
I don’t know if iCloud has a similar feature.
Anyway, I find Dropbox very straightforward and simple to use for things like sharing files with my CPA or debugging logs with some people I work with.
There are some sharing things that MacOS doesn’t seem to do as well as other services. Again, I haven’t tried this in MacOS 27 yet so don’t know. But sharing photos is much more flexible with Google Photos than with Mac Photos, so I continue to synch my entire Photos library with Google Photos even though they are not free anymore. It’s just $4/month for 2 TB of Google cloud storage.
In a sense I believe iCloud does offer something similar, but it’s more convoluted than with Dropbox. You need to change the setting to upload all your Documents to iCloud. Then you pin only the smaller files to stay downloaded locally. In that way larger files will be only in the cloud (unless you tell it to download to local) with just their stub remaining on your local Finder display.
See also this discussion. My main Time Machine backup uses an SSD and NVMe enclosure. But I also use other SSDs and hard drives (for TM and CCC).
After much patient help with testing from Mike at Bombich it does seem clear that my CCC problem was, in fact, an issue with performance on my 5 year old WD 2TB external drive. I’m looking at other drives now so I can continue using CCC, as I have for years.
Which enclosure had the flaky connector?
Is this a question for me? If so, sorry, I don’t understand the question. The drive that seems to be very slow in copying to is a WD 2 TB hard drive I bought in 2021 when I got my MBP. I don’t know if it had to do with a connector.
The linked discussion mentions possible problems with Orico SSD enclosures.
@doug2, do yourself a favor and just replace that flaky HDD with something that’s simple, silent, and works.
This is a quality yet affordable 2TB SSD. It has more than enough throughput for CCC/TM/backup. Put it into this inexpensive USB4/TB4 case — that takes about 1 minute to do and requires nothing but a screwdriver. The total comes to $290, and we can say thanks to the AI folks for that, but you’ll have a clean, simple, and silent setup that just works giving you peace of mind for many years to come.
I’ll check that out. Mike was recommending a 4TB backup drive though. I’ll see what’s available.
I’m right there with him. If you could use more space than the 2TB you were replacing and you can afford it, bigger is better. It is a bit painful though: 4TB is $569.
@doug2
I think you’ve mentioned in the past you’re not located in the US but for backup purposes, especially with the decline of bootable backups, most people will be fine with a traditional HDD for backups. So, at the moment, a 5TB portable drive is about $300 and a 5TB desktop drive is about $220 on US Amazon. Both of these drive models are Wirecutter picks.
That is quite high. I will consider other alternatives.
I’ll check those out. I continue to use a 5 TB portable drive from WD and it’s still working ok with my Time Machine backups.
Thanks. Thought it might be.
