HomePod sounds tinny
I have a 1st gen HomePod that used to sound great. Haven’t listened in a few months and now the sound quality is horrible. Sounds tinny like listening to the cheapest computer speakers.
Any idea what happened?
Before digging too deeply looking for a solution, look at its environment. Depending on what it is sitting on or near, it may be causing something else to vibrate, creating messy sound.
I had this problem years ago in a car of mine. One of the rear speakers would start buzzing at certain frequencies and volumes. It was really frustrating, and I eventually learned to live with it.
Until I decided to upgrade the speakers. Then, after removing the rear shelf-liner (to get at the speaker mount) I found a metal washer sitting loose on the metal. It may have been sitting there since the car was made. I removed it and ran a quick test before replacing the factory speakers, and found that that eliminated the buzz.
Your equalization or soundscape settings changed, possible due to a software update or a power-off/power-on cycle occuring.
He Comes Highly recommended.
Apple HomePod Repair Service
If nothing is wrong, he won’t fix anything, just clean it up and ship it back.
Also he does preemptive fixing of components known to go bad.
Sounds (!) like a hardware issue.
But I have experienced audio problems with a pair of 2nd gen Homepods used with an Apple TV. Recent software updates seem to have led to poor audio when streaming movies.
However a single Original Homepod still sounds good after recent software updates.
I just played music on my 1st Gen HomePod, and it sounded perfectly woody. I would try these things in any order: try different source audio, physically move the HomePod, unplug it and let it reboot, and if none of these help, reset the thing (using the Home App, I believe, but its been a while since I’ve done that, so there could be a different preferred method currently).
I also notice there is a toggle on the HomePod/Home app setting to Reduce Bass. Perhaps this was inadvertently switched on?
I seem to recall that Home Pods “sampled” its surroundings to give best sound output. Am I remembering correctly? And if so, how to invoke it onto an existing set up? I have two set up in stereo mode.
So I did a factory reset and it seems to be better.
The pod is mounted in a wall bracket, so hasn’t moved for a very long time if that was an issue.
I also have checked the Apple Music settings in the home app and all look good. Also the reduce bass setting is off.
Still doesn’t sound as great as I recall, but maybe I’m misremembering
Time for an ear-cleaning?
More seriously, is it possible to remove the HomePods’ fabric covering and check for dust and debris accumulations in the speakers? And to wash/vacuum the coverings?
