Hi you all!
I teach to 4th graders and every year, I have my students doing a little programming using XLogo. They love it.
https://xlogo.tuxfamily.org/fr/telechargements-fr.html
My problem? Why can’t I have XLogo running on the High Sierra driven Macs I am using? XLogo is written in Java (last version April 2009, it is old(!)) and needs a JRE to run. I have Java installed on all machines I use but it does not work.
Last login: Sun Apr 29 09:15:56 on console
iMac-de-Pierre:~ pierrefortier$ java -version
java version “1.8.0_161”
Java™ SE Runtime Environment (build 1.8.0_161-b12)
Java HotSpot™ 64-Bit Server VM (build 25.161-b12, mixed mode)
I read about an older version of JRE that can be installed on High Sierra driven Macs. Is that what I have to install?
https://support.apple.com/kb/dl1572
No one I’ve talked to for the last months had an answer to that question. Would you know what to do?
I thank you in advance for any hint that could help me solve my problem!
PLJF
