Do You Use It? VPNs
I use WireGuard (Fritz!Box and iOS) to establish a permanent secure channel between my two homes and to connect with my mobile devices to my home network.
I use a VPN offered through Bahnhof, my ISP in Sweden. https://bahnhof.se/ The VPN is known as “Integrity VPN” https://integrity.st/ and is part of the “5th of July Foundation”. https://5july.org/ It uses the WireGuard protocol. https://www.wireguard.com/ While many companies talk about how important your privacy is to them, Bahnhof actually has a long history of demonstrating this commitment. Here is an article from Torrentfreak published in 2018. The ISP That Fights For Privacy and a Free Internet Bahnhof: The ISP That Fights For Privacy and a Free Internet * TorrentFreak
I’ve been using Freedome VPN on my devices for several years. I mostly use it when I’m traveling. I do also use Cisco AnyConnect VPN to connect to my employer, but only every 90 days when I have to change my password.
I’ve tried several VPNs, mostly to reach “home” for streaming services I couldn’t watch while I was abroad. In my opinion, ExpressVPN offers the best service for this purpose. Both MLB and Netflix are adept at identifying VPN connections and denying access to their services. ExpressVPN appears to have the best success in bypassing these restrictions, at least in my experience.
At home, I have AT&T Gig service, and I also appreciate that ExpressVPN is very fast. When I’m visiting sites I don’t necessarily trust, it doesn’t affect my online experience by slowing everything down to a crawl.
How would you rate Cloudflare’s 1.1.1.1?
Our office uses GlobalProtect from paloalto networks and Fortinet from Cisco systems.
Other than hooking up to your employer’s network (instead of your own or the local one, say, in a café or hotel) or accessing material restricted from the country you’re in or from the IP you’re at (say, a news article (note: streaming services may know the IPs of VPNs and bar them)), people use VPNs for privacy and piracy, so your own IP address doesn’t show up in your ISP’s logs or the logs of a web site you’re visiting.
I use hide.me VPN when I use one (which is only while traveling); and since I don’t travel that often, I want one I can subscribe to through Apple on a monthly basis only when needed. Most of those available through Apple require a yearly commitment. The rest of the time I just rely on Private Relay on all my devices.
Tunnelblick https://tunnelblick.net
For the first question, I answered “All the Time” but that is not technically true. There are many times when a website won’t work with my VPN enabled. I can’t give any examples off the bat, but it happens sometimes, and it is annoying that I have to disable it just to complete a form or even access the website or something else on a website. But aside from that it is on all the time.
I guess I am dense but I don’t understand the difference in question 2 between “Privacy” and “Anonymity”. In my mind, they seem pretty similar. I guess as noted, one is to hide the IP address one is to hide identity, but it seems that doing one will do the other, no? But what do I know?
I forgot about Tunnelblick. A startup I worked with a couple of years ago used it. It had the advantage of being free, but it was not the easiest to set up. Overall, though, it seemed to work well.
Nope. When I’m out and about, I just use my phone’s cellular connection. And I can’t remember the last time I visited a coffee shop for any reason.
When I’m traveling and I’m on a hotel network, there may be someone snooping, but as I wrote before, just about every web site (and especially anything with potentially sensitive data) is already HTTPS encrypted.
I really don’t care if some random spy sees that I’m visiting my bank’s web site, or streaming video from YouTube. As long as they don’t see the content of my session, I’m fine with it.
For work, I use Tunnelblick, provided by my employer. At home, I have Intego Privacy Protection. The latter, incidentally, often uses servers that Google balks at, requiring a captcha to proceed.
Thank you for helping. Everything you said is common knowledge that I have gleaned from mentions of VPNs over the years.
What is never said is how you actually set up and use any given VPN. Having tried to use one in the past, I found that downloading and installing one does nothing. Apparently they need to be configured somehow. Or they do nothing I can see or monitor. I understand what you can do but I’m astonished that nobody has ever explained how.
Can anyone help me find any articles explaining what to use a VPN for, how to configure it after installing it, and how to verify it works? Will it create a connection to a home machine with sharing turned on over the internet? I’ve often wanted to do that.
Yeah, a bit complicated but instructions are pretty good and make it fairly painless. Also, I guess I should have named the VPN as actually FrootVPN (https://frootvpn.com) using Tunnelblick. It’s not actually free but pretty nominal - $2.99/mo. Usually use the server in Sweden, good reliability and get really good speeds.
I had Nordvpn for 3 years until about 3 years ago. Being polite, their tech support was useless (the comment above about ‘erase your phone, let’s see if that works’ resonates), and it would drop constantly. I don’t think it ever stayed up for a full day on phone or mac. And it wouldn’t tell me it’d dropped, I had to notice. Useless. I’m surprised it topped the poll.
It depends greatly on the specific VPN.
My experience (with remote access VPNs like Cisco AnyConnect and OpenVPN on Windows) is that you install the software. Then you configure it with things like:
  • The name/address of the server you’re connecting to
  • The user name and password for the connection (or you’ll have to type them in whenever you connect)
  • Any options (e.g. split tunneling, exceptions for LAN connections like your printer, etc.)
Some of these may be automatically populated by the installation script (e.g. the one my IT department gave me to do the installation).
Then when you want to connect, click on its icon (in the Windows system tray. Presumably there’s a menu-bar icon on Mac versions) and tell it you want to connect. Provide login credentials if requested and it should connect soon afterward. Once connected, your network traffic will be shunted through the VPN’s connection (via specially-crafted entries in your computer’s routing table).
If it is doing its job properly, you shouldn’t notice it is running. All your network traffic will flow from your computer to the VPN server and from there to its destination (possibly making a few hops through the VPN provider’s network on the way). Without network diagnostic tools (to see that the routes have changed), you shouldn’t notice any change.
When you’re done with the session, click its icon and tell it to disconnect. The app should remove the routing table entries and close the network connection to the VPN server.
I would like to assume that private-browsing VPNs behave similarly. Hopefully with a more user-friendly configuration interface (e.g. select the server from a list of options instead of making you type it in manually). But I haven’t used those products, so I can’t be sure.
I used PrivadoVPN (https://privadovpn.com) when a website wouldn’t let me buy because it is US based and I’m not. I can understand not offering shipping outside the US but I was buying a gift for delivery to my parents who do live in the US!
I use two different VPNs (one at any one time) on all my devices, since there are certain sites that work with one but not the other. I’ve been using personalVPN (formerly known as WiTopia) (https://www.personalvpn.com/) for many years and continue using it because it generally seems to not slow my system, and it’s been around so long that I have faith in it just due to its longevity. Unfortunately, there are a few sites that seem to have problems with it, but work OK with the other VPN I use sometimes, that being 1.1.1.1 (https://1111-w-warp.en.softonic.com/), which I chose because of its advertising that it was secure and fast, and like personalVPN, it does seem to not slow the system down (though admittedly I haven’t noticed the actual speed boost it claims to provide). Since they both appear in the VPN option in Settings and connect when I set them to connect (again, only one at a time), I’m just assuming they work as advertised - I’m not enough of a techie to delve into the inner workings to investigate further. There are of course some sites that work with neither VPN, and likely simply don’t work with devices connected via any VPN, Ticketmaster being the most annoying.
