Can a work around be to fill the disk up with unimportant files and then encrypt?
To a certain extent. That will work if no blocks have been blocked (marked bad by the controller). If not, which could be quite likely on an older drive, the question then becomes if potentially sensitive data could persist there regardless of user action. Again, this becomes an issue of how paranoid you have to be.
Writing random data to a huge device-filling file and then erasing it is equivalent to a secure-delete operation.
All of the user-accessible disk blocks will either be random data or zeros (depending on if TRIM is used), and your old data will be garbage in the flash chips, until garbage collection runs.
Encryption at this point will be as I wrote, above. The data will be inaccessible to anyone who isn’t able to bypass the SSD controller.
How would you do that ? thank you
I read somewhere that if you fill an SSD drive more than 3/4 full (or some similar number) it will cause slowdowns and even if you delete the files, the slowdown stays. Is that true?
That’s related to garbage collection. If you write to 100% of the disk, then delete 1% of it, and the you want to add 1%, GC first needs to run to ensure that the 1% becomes available again. If GC hasn’t already done so (if the SSD is left idling for long enough, GC should always run), that needs to happen right then and there, and that can introduce a penalty. By ensuring ~20% of the SSD remains unused (and I readily admit that is a conservative estimate these days), you increase the chances that you have blocks readily available any time you want to write. Note that advice to not partition these 20% is nonsense (perhaps related to provisioning missing on early SSDs, see below). It’s perfectly fine to partition 100%, just don’t occupy every last bit with data.
It’s worth pointing out also that this shouldn’t be mistaken with leaving space to make up for bad blocks that get mapped out by the controller. SSDs already provide that and any decent model you buy today will come with ample such extra space included. It’s called provisioning. On higher-end SSDs intended for example for servers (where you anticipate very many write cycles), that can amount to as much 50% from what I’ve been told.
And finally, if you have TLC flash from certain manufacturers that doesn’t come with large DRAM cache, it could be you’d want to leave free space because of dynamic provisioning. If you leave more of the SSD free, certain drives will switch TLC cells to function as SLC which can increase performance significantly. If you have such a drive and you let it fill up, you are essentially forcing it to run entirely as true TLC with the associated penalty over “pseudo-SLC”.
After reading your post, I read about TRIM because I found interesting the fact that formatting with TRIM insures a secure erase.
I checked and all Samsung SSD drives are trim enabled. However, it seems that Mac recognizes the trim only if the external SSD is connected with a Thunderbolt cable.
This surprised me and indeed when I plug my Samsung T7 portable which works perfectly, the system report does not report TRIM supported when connected via either USB A or USB C. I don’t have a thunderbolt cable to test that type of connection.
I am sure that you highly performant EVO is TRIM “capable” but is it enabled in your mac ?
I would make a big file in Photoshop PSB format. If you do not have Photoshop you can download a trial.
Te easiest way to create a file that fills all your free space is to use the command line:
cat </dev/zero >bigtempfile
Once you run out of disk space, the command will fail with an error message. You can then immediately delete bigtempfile. Be aware that, if you’re doing this on your boot drive, your system will become unstable as the system disk approaches full.
Edit: the above command will create bigtempfile in the current directory (“folder”), which will default to one on the boot drive. If you’re wanting to do this on something other than the system drive, you need to specify the localtion of bigtemptfile:
cat </dev/zero >/Volumes/[driveToBeErased]/bigtempfile
thank you. Perhaps a video ?
thank you very much.
@ron
Because I am bungle prone, How could I insure that it’s the external SSD being filled up ?
@ron @paal
Isn’t secure delete exactly that: filling in the disk with 0 and 1 ?
Secure delete overwrites most of the disk, yes. I was focusing on the question of “how do I create a file that uses up all the free space?”
As others have said, the correct answer is to always use whole-disk encryption from the beginning. Sometimes, the “create a big file of zeros” technique is useful when you have an unencrypted disk, don’t necessarily want to erase all the files on it, but want to make reasonably sure that information from previously deleted files isn’t trivially recoverable. I realize that isn’t the context in which the question was asked.
The problem this whole thread seems to be struggling with is the fact that modern systems, with smarts in the disk (SSD) controller and complex features in the file system, make it difficult to make absolutely sure that your storage medium is actually 100% erased.
Just to be clear: I was trying to understand. I did not mean to question your approach,
If I understand correctly
- it’s not 100 % as you say
- at the same time, I gather from other posts that recovering the data would be quite an endeavour. It would take a determined hacker, not just a service repairman at my local apple service store.
thanks again
That’s not so much about the cable but about macOS driver support. So just attaching your T7 to a TB port with a TB cable won’t change any of that.
You’d need an actual TB drive, i.e. flash memory interfaced to your Mac over TB (such as an X5). There are TB-NVMe cases and they work fine, but they’re usually much more expensive than USB-attached SSDs which commonly bridge either SATA (slower, cheaper) or NVMe (faster, more expensive, can require cooling to ensure real benefit) to USB 3.x. Of course they also offer much better performance, especially when they are cooled.
The bottom line here is that macOS supports TRIM on external drives when they interface through PCIe, but not USB*. Macs have IMHO always had somewhat mediocre USB drive support. The keyword here though is PCIe and that’s why TB-attached drives get it (TB is based on PCIe) and USB-attached don’t.
*) The exception being drives with bridge chips that support UASP. Those drives should allow for TRIM, well technically UNMAP (in SCSI terminology, TRIM is what it was called as an ATA command) when attached to a Mac over USB. I’m not sure if the T7 actually supports this. It’s been a long time since I looked into this, but IIRC you should be able to check if the drive you’ve attached is making use of UASP by running a
ioreg | grep IOUSB
and checking on the line for your drive it you see something like
class IOUSBMassStorageUASDriver, id 0x100008489, registered, matched, active, busy 0 (100 ms), retain 9
The active part is what you want to see.
My memory here is a bit foggy so I’m hoping somebody will double-check me on that.
BTW, those 970 EVO I was playing around with are NVMe-interfaced flash that we hook up using a TB3 enclosure (OWC Envoy Express is an inexpensive example, but also no active cooling—there are fancier alternatives) so they’ll always show TRIM support since the Mac talks to them through PCIe, just as it does with its internal flash.
This is definitely correct.
It’s not like anybody attaching that old drive and accessing it through its built-in controller would be able to read out your old data. Accessing such leftover data would require bypassing the controller (so for example T2 or M1/2 Macs make that impossible right away thanks to their built-in hardware-level flash encryption regardless of users’ specific FV2 choices) and reading out flash cells directly.
To be clear: that can be done. Forensic analysis attempts to do exactly that and there are ample cases where it has shown to have been successful. However, it is also correct to point out that this is very involved, requires lots of time, expertise and hence money.
If you are a Russian dissident who is harboring information that could topple Putin, you would absolutely be at risk. Or if you are a multi-billion $ company who has its trade secrets on an old company notebook one of your dunce employees just forgot at the gate. But any regular Joe like myself is most likely not at great risk for that attack vector—it’s just too much effort for too little gain. There are much cheaper methods to scam me, rip me off, or access my staff’s PII from one of my systems (eg. social engineering [I like to believe I won’t fall for that] or much simpler, just pointing a gun at my head). XKCD as usual had a good summary of that.
Very wise precaution! So the cat </dev/zero part on its own is harmless. You want to be sure the output has the right target. Using the template @ron gave you above, you have by now likely a best guess of that target. Let’s say you’re pretty sure it’s /Volumes/TroublesomeSSD/bigtempfile. Try this command first, just to validate the target:
echo "TidBITS Talk is wonderful!" > /Volumes/TroublesomeSSD/bigtempfile
That will complete in an instant. Then, if you see the file bigtempfile on your SSD, you’re in business. If not, you’ve only written a 26 byte file to the wrong target.
thanks VERY much for a brilliant explanation. The cartoon says it all !
excellent approach. Thanks very much.
Your comments are so interesting ! I am writing a summary.
If you have the patience - I am completely new at this.
Below is a typical SSD I use for backup
- do I have to repeat the terminal command for all disks , ie disk7S1 to S4 (column on the right) or the physical disk6s2 ?
- it’s not clear for me what I should write in place of volume
- could you give one example of a terminal command based on this actual drive ? I am trying to figure out what to write in the place of
- in the command, do I include / / and ?
thanks very much
