Those of you of my age will remember an app called Keep-It-Up that monitored apps to check if they are still running and if not tried to reboot.
Is there anything out there that will do something similar on MacOS? I understand I can create a daemon and take advantage of the system’s launchd daemon manager but was wondering if there were any apps out there that will do the same thing (or a more elegant way of doing this)?
@trilo mentioned Lingon. I prefer LaunchControl from soma-zone. You can drag the icon for the app you want to keep running on the LaunchControl icon and it will automagically create a LaunchAgent, either for the current user (e.g. in ~/Library/LaunchAgents) or for all users (/Library/LaunchAgents).
As an aside, I used to use several products (PowerKey & Kick-off!) from Sophisticated Circuits with my ADB Macs to keep things running. I don’t think they are around anymore .
Wow, Kick-off!, that is going back a bit, I used to run that on a Power Mac G4 450. Machine still works and I only sold it very recently (was well over 20 years old)…
