When sharing an iCloud Drive folder with others, I find that any file that a recipient opens up/views is downloaded to the recipient’s computer (for certain) and, if they are using a tablet or smart phone instead, (maybe) to their device.
While I use and like iCloud Drive for many things, file and folder sharing is not one of them. I liken its behavior to inviting a neighbor over to view your TV and, while he’s watching your TV, you’re taking all your storage boxes out the back door and putting them in his garage. He’s involuntarily, unknowingly storing your goods. You aren’t being a good neighbor, and neither is iCloud Drive in this scenario.
I have no problem with the recipient downloading files if and when they choose, but I do have a problem with a download ocurring simply because the recipient wanted to view a file to see if it was important enough to keep.
Hence my question. Are there any good alternatives to iCloud Drive for sharing? In my case there are about 90GB of files and folders to share with 40-50 people, some of whom have only a limited hold on computer technology, others of whom are very impatient and will immediately start opening all sorts of files as their fancy strikes.
Are there alternatives that don’t penalize just viewing a document?
Thanks
