TidBITS: Final Cut Pro X 10.4, Compressor 4.4, and Motion 5.4
classic Classic list List threaded Threaded
1 message Options
Reply | Threaded
Open this post in threaded view
TidBITS Articles
This article was just published by TidBITS and sent to you at your request.
By Agen G. N. Schmitz
http://tidbits.com/article/17692
Updating in tandem with the release of the new iMac Pro (see "Apple Releases the iMac Pro," 15 December 2017), Apple has issued Final Cut Pro X 10.4, Compressor 4.4, and Motion 5.4 with a focus on 360-degree VR video support. You can now import and edit equirectangular video from a wide range of formats and frame sizes (including monoscopic and stereoscopic formats) into Final Cut Pro and Compressor, plus send 360-degree video output to a connected VR headset from Final Cut Pro and Motion.
From Final Cut Pro, you'll be able to simultaneously monitor headset and equirectangular views while editing from the 360-degree viewer, use the Horizon overlay to change a video's orientation, and utilize a patch to instantly remove cameras and rigs from the scene. Both Final Cut Pro and Motion enable you to place, reposition, and resize any graphic, still, or video in a 360-degree video project, apply effects such as blurs and glows to 360-degree video, and share videos directly to YouTube, Facebook, and Vimeo. Compressor adds support for exporting 360-degree video files with embedded industry-standard spherical metadata.
The professional video editing apps also bring a lengthy list of new features and improvements as well as bug fixes.
Final Cut Pro X 10.4 -- The update brings new tools for color grading, with a dedicated color tab in the inspector that collects all color controls. New color wheels improve upon traditional wheels with integrated sliders to adjust hue, saturation, and brightness, while color curves provide ultra-fine adjustments and hue/saturation curves enable you to make brightness adjustments while leaving other parts of the image unchanged.
Beyond color grading, here are some highlights from Final Cut Pro's other improvements and fixes:
  • Adds support for importing, editing, and playing of High Efficiency Video Coding (HEVC) video clips and High Efficiency Image Format (HEIF) photos.
  • Directly import an iMovie for iOS project for advanced editing, audio work, and finishing.
  • Import, grade, and deliver High Dynamic Range (HDR) video as Rec. 2020 HLG or Rec. 2020 PQ for HDR10.
  • Import and export WAV files greater than 4 GB as RF64 when using macOS 10.13 High Sierra.
  • Fixes a stability issue that occurred when using Final Cut Pro on High Sierra with a laptop in closed-display mode and attached to an external monitor.
Compressor 4.4 -- The video conversion and output tool also adds support for HEVC files, compacting file sizes up to 40 percent smaller than H.264 with the same video quality. It also provides controls for color space conversions and metadata for HDR video, as well as enables you to convert HDR to Standard Dynamic Range (SDR) video. Other highlights include:
  • Adds support for encoding MXF files with compatibility for a wide range of codecs and parameters.
  • Correctly identifies frame rates for iPhone movies.
  • Addresses an issue with Panasonic GH5 MP4 files exported to ProRes that produced three green frames at the beginning of a file.
Motion 5.4 -- The motion graphics tool now enables you to convert between a Motion project, Final Cut Pro generator, Final Cut Pro title, Final Cut Pro effect, or Final Cut Pro transition at any time. In addition to adding support for HEVC videos and HEIF photos, the update also brings these changes:
  • Send to Compressor to export motion graphics projects in the HEVC format.
  • Improves speed and quality of Optical Flow analysis using Metal.
  • New Overshoot behavior creates realistic spring-loaded animations without the need for keyframes.
  • Resolves issues with the Time Date Text Generator 24-hour clock.
  • Trailing punctuation in a text sequence now animates correctly.
All three video apps now require a minimum of OS X 10.12.4 Sierra. (All three apps receive free updates. Otherwise, Final Cut Pro X, $299.99 new, 3.02 GB, release notes, 10.11.4+; Compressor, $49.99 new, 393 MB, release notes, 10.11.4+; Motion, $49.99 new, 2.38 GB, release notes, 10.12.4+)
Post a comment
TidBITS members can unsubscribe from just-published articles at http://tidbits.com/subscriptions. TidBITS Talk readers will need to create a filter to delete these articles.
Article copyright © 2017 By Agen G. N. Schmitz . Reuse governed by Creative Commons License.
____________TidBITS Talk Participation Guidelines____________
Post only when you have something substantive to contribute.
Be polite and constructive, and comment on posts, not people.
Quote sparingly, if at all. We all read the previous message.
Start threads with a new message to [hidden email].
Read archives at: http://tidbits.com/pipermail/tidbits-talk/
Unsubscribe at: http://tidbits.com/mailman/options/tidbits-talk
____Mailing List Manners: http://tidbits.com/series/1141 ____
