Re: SYSTEM FAILURE upon USB plug in of ALFA Long Range USB Adapter (11n WLAN) (Harald Sundt)
classic Classic list List threaded Threaded
2 messages Options
Reply | Threaded
Open this post in threaded view
Thom Ryan
Now I am perminantly poor and must let my iPhone turn into an iPod and
use WiFi to access my local Cottage Grove OR Public WiFi.
I am desperately trying to make my
AWUS036H ALFA Long Range USB Adapter
(11n WLAN)
work with my Mac Tower running Mac OS X 10.6.8 (10K549).
This WiFi booster enable my Linux/XP Dual Boot laptop able to reach my
City's feeble signal.
AFTER installing the  ALFA provided software I THEN plug in the USB
cable to the WiFi booster and the system crashes in gray multi-lingual
FAIL.
Greetings Harald and Tidbits List
I have some experience with USB wifi and kernel panics.
1-The power demands from a USB wifi device are variable with
throughput, range and sensitivity.
The reason you are using a USB wifi device is because Apple engineers
have carefully controlled the internal wifi to limit battery drain.
2-The Apple USB ports are not equal; one port will be shared
internally with the keyboard, iSight, etc.
The System Profiler will reveal the "unshared" USB port; try this port
with your power hungry USB wifi device.
Turn off the internal wifi. The kernel panic could be a power management issue.
This approach did delay the kernel panic in my case but the system
would fail over 24 hours (solved issue 2 but not 1.)
I still use my Quickertek USB wifi device with the marked USB port
when working in "portable" mode, (i.e. automobile) knowing that a
kernel panic can happen.
My long term wifi piggyback solution needs line power for a POE
connection to a Ubiquiti Nanostation Loco working in "station" mode.
I distribute the Nanostation through an Airport Express network for
everything (Skype phone, laptop, iPod, printer.)
The Nanostation LoCo is tenacious with distant access points and a
poor piggybacker's dream that will pay for itself in less than two
months.
Don’t tell your ex.
Kind regards
____________TidBITS Talk Participation Guidelines____________
Post only when you have something substantive to contribute.
Be polite and constructive, and comment on posts, not people.
Quote sparingly, if at all. We all read the previous message.
Start threads with a new message to [hidden email].
Read archives at: http://tidbits.com/pipermail/tidbits-talk/
Unsubscribe at: tidbits.com/mailman/options/tidbits-talk
____Mailing List Manners: http://tidbits.com/series/1141 ____
Reply | Threaded
Harald Sundt
Thank you Adam and Thom. I am scrambling even as we speak.
Thanks again.
“the ancient destructive urges in, us, that grow more deadly as our populations approach in size and complexity those of ancient Mars. Every war crisis, witch-hunt, race riot and purge…is a reminder and warning. We are the Martians. If we cannot control the inheritance within us…this will be their second dead planet!”
quote: Dr. Bernard Quatermass of the The British Experimental Rocket Group
The BBC TV serial miniseries version of "Quatermass and the Pit" 1957.
